Question Do I need a fan header for my build?
Mar 8, 2019
54
Hello! I am here to ask if i need any extra fan headers/splitters for my build, since I am planning to install 4-5 fans. 3 in the front and 1-2 in the back. Here's my build
PCPartPicker Part List: https://pcpartpicker.com/list/TfrNkd
CPU: AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor ($79.99 @ Amazon)
Motherboard: ASRock B450M-HDV Micro ATX AM4 Motherboard ($69.46 @ OutletPC)
Memory: Corsair Vengeance LPX 8 GB (2 x 4 GB) DDR4-3000 Memory ($44.99 @ Amazon)
Storage: Western Digital Blue 1 TB 3.5" 5400RPM Internal Hard Drive ($45.58 @ OutletPC)
Video Card: PowerColor Radeon RX 570 4 GB RED DRAGON Video Card ($129.99 @ Newegg)
Case: Cooler Master MB600L ODD ATX Mid Tower Case ($40.98 @ Newegg)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($53.88 @ OutletPC)
Case Fan: Deepcool RF 120 (3 in 1) 56.5 CFM 120 mm Fans ($32.99 @ Amazon)
Total: $497.86
Generated by PCPartPicker 2019-09-01 09:51 EDT-0400
Phaaze88
Admirable
Herald
After checking the motherboard's specs - the CPU FAN1 and CHA FAN2 headers support a max of 1A(amp) of power, and the CHA FAN1/WP is 2A.
A single Deepcool fan is rated at 0.23A: http://www.deepcool.com/product/dcoolingaccessory/2017-07/12_6835.shtml
You could daisy-chain up to 4 fans on a single 1A header, and to 8 on the 2A one, if you wish.
Options
-2 Y-splitters
-1 3-fan splitter
-1 4-fan splitter
Then again, the power rating on the included case fans also matter.
Mar 8, 2019
54
Options
-2 Y-splitters
-1 3-fan splitter
-1 4-fan splitter
Alright, sorry for the late replying, but actually I wanted to buy the RF 120R (red), pcpartpicker does not have it, so I can't send the link. So I heard that the RF 120R draws 0.17-19A. should I still buy more fan splitters? Because it draws WAY less power than the RGB version
Phaaze88
Admirable
Herald
Are you purposefully trying to daisy chain 4-5 fans to one header? Otherwise, your options are no different from the previous RGB model.
