I built a pc 1 month ago for music production that will live its life offline.
Asus Prime-P Z790 WiFi D5,
i7 13700k, 32 gb ram, noctua air cooler in a 4U server case. It runs about 32c under its max workload in Studio One 6.5.
Anticipating this build 1 year ago I bought a sold as new gtx 2060 for this build. Just now I had to remove it. Motherboard no longer posts with it installed. At close examination it appears the GPU is actually used and spent.
Can the i7 13700k's built-in GPU power two HP Compaq LA2405x 24 monitors? The Intel GPU output is a DisplayPort and an HDMI. My monitors have DisplayPort inputs but no HDMI input. To gain use of my second monitor do I need to replace the 2060 or can I get an adapter -use both built-in Intel GPU outputs? If it can use both Intel outputs, What is the right converter cable for getting HDMI output to DisplayPort input?
