Do I need a new monitor or no?, is my system good with the current monitor I have? (spec included)
PedramCarter
270
This is my monitor,
http://www.canadacomputers.com/product_info.php?cPath=22_1195_699_1099_290&item_id=060295
And this is the current system specs I'm going to build (Waiting for components to be delivered)
Should I order a screen too? or is the one I have good enough? I don't want to waste money if its not needed if it is or would make big difference then I will
Vantage Midi ATX PC Gaming Tower
(The cooling system is developed for cooling throughout
4 x Built-in 12cm Fans (3 x Blue LED) will keep your components cool
Water Cooling Ready *not included* )
Processor AMD FX-8350 4.0GHz Socket AM3+ Octo Core
Motherboard
ASUS® M5A97 R2.0 (DDR3, USB3.0, 6Gb/s)
Memory (RAM)
8GB KINGSTON DUAL-DDR3 1600MHz (2 x 4GB)
Graphics Card
4GB AMD RADEON™ R9 290X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
(battlefield 4 edition, free bf4 included)
Memory - 1st Hard Disk
1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply
XFX 650W PRO650W Core Edition.
Processor Cooling
STANDARD AMD CPU COOLER
Sound Card
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
USB Options
MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Its not a 1080p screen, but honestly it doesn't much matter. I got a 1080 screen that was pretty good last year, ended up giving it to my nephew and kept my screen with the same resolution as yours b/c I like the looks of it, and the aspect ratio (kinda an oddball ratio but I like its looks). Its up to you if you still like your monitor just use it on the new build. if it bothers you then upgrade after the fact. Won't hurt to wait on it as it won't directly affect performance.
