Question Do I need a new power supply unit? PSU Issues
Aug 13, 2023
PSU Issues​
Hello ! Any advise would be great​
History- issues started 1 month ago. Chrome would need to be restarted, tabs would not work or the whole computer needed to be restarted.​
went to cmd and run powercfg -energy
fist report found many errors, which I was able to fix.
Still have not had enough time to see the full affects of the changes. Still had to restart at least once or twice.
PSU is 5+ years old
Windows 7, desktop, i5 Intel, sound and audio cards
not a gaming computer, some Steam games
Question- Do I need to replace PSU, if so, minimum watts?
Thanks in advance..........
Power Efficiency Diagnostics Report​
Computer NameUSER-PC
Scan Time2023-08-14T01:24:48Z
Scan Duration60 seconds
System ManufacturerGigabyte Technology Co., Ltd.
System Product NameH81M-DS2
BIOS Date08/06/2015
BIOS VersionF2
OS Build7601
Platform RolePlatformRoleDesktop
Plugged Intrue
Process Count66
Thread Count1054
Report GUID{eec5596e-cef6-4095-8180-3f55ab61bde3}
Analysis Results​
Errors​
Platform Power Management Capabilities😛CI Express Active-State Power Management (ASPM) Disabled
PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
Warnings​
Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
Information​
Platform Timer Resolution😛latform Timer Resolution
The default platform timer resolution is 15.6ms (15625000ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
Current Timer Resolution (100ns units)156000
Power Policy:Active Power Plan
The current power plan in use
Plan NameOEM Balanced
Plan GUID{381b4222-f694-41f0-9685-ff5bb260df2e}
Power Policy😛ower Plan Personality (Plugged In)
The personality of the current power plan when the system is plugged in.
PersonalityBalanced
Power Policy:Video quality (Plugged In)
Enables Windows Media Player to optimize for quality or power savings when playing video.
Quality ModeOptimize for Video Quality
System Availability Requests:Analysis Success
Analysis was successful. No energy efficiency problems were found. No information was returned.
USB Suspend:Analysis Success
CPU Utilization😛rocessor utilization is low
The average processor utilization during the trace was very low. The system will consume less power when the average processor utilization is very low.
Average Utilization (%)1.06
Battery:Analysis Success
Platform Power Management Capabilities:Supported Sleep States
Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
S1 Sleep Supportedfalse
S2 Sleep Supportedfalse
S3 Sleep Supportedtrue
S4 Sleep Supportedtrue
Platform Power Management Capabilities😛rocessor Power Management Capabilities
Effective processor power management enables the computer to automatically balance performance and energy consumption.
Group0
Index0
Idle (C) State Count2
Performance (P) State Count16
Throttle (T) State Count0
Group0
Index1
Group0
Index2
Group0
Index3
"Let's get a full list of specs, including *exact* PSU" newbie........ exactly how does one get this data?
Things like Speccy can tell you some of the equipment. The PSU you have to identify by looking at it.
The easiest way to find the specs otherwise would be to check the documentation from when you purchased it. Presumably you chose to buy the PC based on something!
