I've been having a problem with my PC it keeps shutting down. My PC specs:
HP Pavilion p6 series
Model: p6-2260ea
Processor: Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz 3.30GHz
Here's some information about the crash:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 2057
Additional information about the problem:
BCCode: 10d
BCP1: 0000000000000005
BCP2: 0000000000000000
BCP3: 0000000000001024
BCP4: FFFFFA8008A5EE40
OS Version: 6_1_7601
Service Pack: 1_0
Product: 768_1
The problem is I don't really know what to do. It's been suggested that I download CPUID's TMonitor. At the time of this typing I realise I have not downloaded Tmonitor but CPUID CPU-Z, not sure if that's any good but I will try to download the correct software but its seems CPU-Z may do the same thing as these other software. However I look at the data produced by this software and I don't know what to look at. I'm also reading an article that says this:
http://www.pcadvisor.co.uk/how-to/pc-components/3503892/pc-shuts-down-unexpectedly/
Your power supply should be delivering 3.3-, 5- and 12V inputs to your motherboard
Well 3.3 - 5- what? Volts? Watts? I'm assuming V is volts. Also mentioning the motherboard seems a bit vague are there specific components in the motherboard that need to be delivered to? I'm just a little bit confused does anybody have any suggestions as to were I should start because I don't want to buy a new power supply for no reason.
One last thing I've been getting problems with my xbox controller disconnecting, I've tried updating software, drivers and putting USB port in the back but it hasn't worked. The only thing I haven't done is check the power supply which can cause the xbox controller to switch off. Maybe the two problems are connected.
Model: p6-2260ea
Problem signature:
Locale ID: 2057
BCCode: 10d
Service Pack: 1_0
Product: 768_1
