No?
Just depends on the capabilities of the panel, cable (connection type), and the GPU. Quadro, Geforce, Radeon, Firepro doesn't really matter. Those are just broad marketing names. And the differences between different generations are vast as much as the cost difference.
As an example you can have a Quadro with the exact same GPU as a Geforce card, the difference is usually only the memory type and the drivers.
Simply look up your GPU's capabilities, If you don't have them, then you can start shopping for a suitable GPU.
