Do I need a NZXT internal usb hub for my build?
According to your PCPartPicker list, there is nothing that needs an NZXT Internal USB Hub. You'd only need one if you had many devices that used up internal USB headers.
Also, this is irrelevant to the question, but you should definately know that: You chose a 2nd generation Ryzen CPU, but only have an X370 motherboard. 2nd gen Ryzen is supported by X470, not X370. Of course, you can update the BIOS on the X370 motherboard to kind-of support the 2nd gen Ryzen, but there's no point to buy an X370 motherboard when you can just buy an X470 motherboard.
Hope this helped!
-Lachlan :)
my cpu is intel i7-8700k
Apologies, the link you provided redirected me to my old PCPartPicker list.
Now the link just takes me to the PCPartPicker homepage.
In the end, my answer above is (I believe) still correct to the original question:
