Do I need a sound card for my Logitech G430?
Derick Lew
34
I'm gonna buy a Logitech G430 and I'm curious to know should I or should I not to buy a sound card for the Logitech G430 since it has 7.1 Dolby Surround Sound (I'm using a Asus Z87-A Motherboard). I also have Realtek HD Audio which supports 7.1 but one things that's bugging me is that do the 7.1 virtual surround works if I don't use the provided USB sound card?
I'm not familiar with these things so expect me to ask further questions..
Any answers will be appreciated. And any headsets/headphones recommendation around MYR 200-300(approx. 60$-80$) will be welcomed as well.
Then you have a lot of options.
Take a look at some of these, you'll need to pick one based on what type of fit you like http://reviews.cnet.com/2300-6468_7-10011889-1.html
I have two SteelSeries headphones and a headset and like them both, this model http://steelseries.com/us/products/audio/steelseries-5hv3 and a higher end XBOX headset that is similar. It's not in the review at cnet but they are good. I like the fit of them a lot.
Thx. Would you recommend me any headphone or earphone that's around my budget? Because I already have a mic built-in web-cam and now I only need headphones or earphones, wireless ones would be great!
But I won't be using the mic so often, and I think buying a headphone or earphone would be cheaper than buying a headset, anything to recommend? As I will listen to music in long distance travel so I don't what the headset-with-mic look.
Thank you very much! I think I found the one for me(ATH M-30).
