GearUp :
I've noted the lack of true grounding many times and in computers that only adds a case. That seems little more protection from the power supply.
First, grounding a computer case says nothing about earth ground. As made obvious in an electrical concept that says why the expression reads 'less than 3 meters'. Safety ground was specifically noted as completely different from earth ground. An adjacent UPS has no earth ground. Earthing a computer can even make computer damage easier. Earth a potentially destructive surge; not its victim.
Second, what cumulative damage? Where did that come from? Why would a UPS do anything to avert cumulative damage?
If cumulative damage is problematic, well, a UPS output can be so 'dirty' as to degrade a connected power strip protector. UPS and protector manufacturers quietly recommend no power strip protector on a UPS output. Dirty power in battery backup mode can degrade that protector. Is that your cumulative damage? Because that same 'dirty' UPS output does not do cumulative damage to attached electronic appliances.
UPS does not protect hardware. A myth - cumulative damage - is not averted by a UPS. Where is any specification that defines cumulative damage? Numbers in datasheets from MOV manufacturers define cumulative damage by dirty UPS power. What cumulative damage are you discussing?.
Third, a $250,000 warranty, safety ground on a UPS, and what makes thousands of joules irrelevant have nothing in common. Effective protection for a computer, microwave and other household appliances is all done by the same solution proven over 100 years ago.
Fourth, surge protector devices that actually do protection are completely different from surge protector devices exposed by spec numbers as ineffective. Confusion abounds where two completely different devices share this common name. A superior and effective solution not only costs tens of times less money. It also does not have that big buck warranty - that exists to promote what is really tiny protection.
UPS has one function - temporary and 'dirty' power during a blackout. UPS does not protect hardware - as demonstrates by no specification numbers to justify that speculation.
