S SidTheSloth Honorable Dec 11, 2013 269 0 10,780 Dec 17, 2013 #1 http://uk.pcpartpicker.com/user/SidTheSloth/saved/38QI I am making this build, someone told me to get a mini itx bored as I wont need one? is it because it is built in to the bored?
xroe Honorable Jan 11, 2013 591 0 11,360 Dec 17, 2013 #2 While some mini ITX boards have integrated wifi controllers, that one does not and will require a dedicated wifi card like you selected if you wish to have wifi capabilities. Upvote 0 Downvote
S SidTheSloth Honorable Dec 11, 2013 269 0 10,780 Dec 17, 2013 #3 The wireless adapter says its a PCI-e card does that mean it will only work in the PCI-e slot or will it work in a normal PCI slot? Upvote 0 Downvote
