Do I Need A Wireless Network Adapter
Wireless is not optimal for gaming. Are you planning on using it? Ethernet cable is best, then powerline network adapters. WIFI is the least stable type network for gaming.
If you believe you have to use WIFI then a separate WIFI adapter would be required. That motherboard has a PCIe x1 slot, but it might be difficult to get a card into depending on your cooler and graphics card. It looks REALLY tight.
