do i need aftermarket cpu cooler.....?
Amit Singh1994
18
i have intel core i7 3770 and i want to run it at stock......playing hardcore games on it.....in spite of these....do i really required aftermarket cooler....?......also tell me what is the temperature range...at stock cooler...?
thanks in advance
The temperature depends on the environment you run it in.
I had instabilities with the stock cooler in my home office, which can hit 80 deg F in summer time.
I highly recommend an after market cooler. Even a cheap $20 one will do quite well at stock speeds.
the after market cooler provide more cooling and it can effect your performance playing in cpu orginal fan got my temp 83c now I have it at 53c while 100% cpu usag so I recommend it
sorry for my bad english
Can you please tell me the temps you get with this CPU on IDLE and while playing a game ?
i have the same CPU and same cooler , and i have high temps. i would like to compare them..
Use a monitoring progrm like HWmonitor to let us know your current temps... but to answer your question, you dont NEED a aftermarket cooler.. but its definately a good idea as most stock coolers wear down quickly. Keep in mind, the better cooling on your CPU over time, will allow for longer lifespan and better performance down the road.
53 on idle try to set it up right and use good thermal paste
