Do I need an aftermarket cpu cooler for this build?
Mar 22, 2013
41
LITE-ON 24X DVD Writer
COOLER MASTER Storm Enforcer
Seagate Barracuda 7200rpm 1tb 3.5 inch
MSI R7950 Twin Frozr 3GD5/OC Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Windows 7 Home Premium
COOLER MASTER R4-L2R-20AC-GP 120mm Blue LED Case cooler
COOLER MASTER Megaflow 200 R4-LUS-07AB-GP 200mm Blue LED Case cooler
I have heard that the cooler master hyper 212 evo is the best aftermarket cpu cooler, but do I need one besides the one that comes with the cpu? I have heard that you don't need one unless you overclock your cpu, which I don't plan to do initially, but if the cpu falls behind in the future I might.
alvine
Splendid
May 13, 2008
4,504
202
cooler master hyper 212 is a good value cooler but its not the best cooler out there. since you picked an unlocked cpu yea i would advise to get a cooler so you can overclock it when you feel like tinkering with your pc. best air coolers are noctua, look into enclosed water coolers such as h80i or h100i....I'm using the h100 and I love it
you can also save some money by downgrading the psu to 650w~
Headbomb
236
17
Yup, If you don't plan on overclocking then you probably won't need it.
I have a Hyper 212 evo and I OC'ed my i5-3570k to 4.5ghz.
Max temps are 65 Celsius.
Really good cooler
USAFRet
104,195
31
150,140
17,768
It's not critical, your system will run fine. But:
They're inexpensive and it is much easier to install it now, than to take everything apart later.
geofelt
39,465
20
137,665
7,960
+1 ^
Need... no.
But I would recommend a cm hyper212. It is<$30. Even without overclocking, the larger 120mm fan will be much quieter and get some of the graphics card heat out of the case more directly.
The backplate mount will be easier too. The Intel pushpin mount can be tricky to do well.
Also, the 7950 only needs a 500w psu, or 700w if you plan on crossfire which I rarely recommend.
Mar 22, 2013
41
Is the 650w psu enough power for this build? because if so, you just saved me about $60 :D
geofelt
39,465
20
137,665
7,960
That is about the size I would buy.
Here is a chart of recommendations: http://www.realhardtechx.com/index_archivos/Page362.htm
Above all, buy only a quality unit. Here is a list for that: http://www.eggxpert.com/forums/thread/323050.aspx
J_E_D_70
Splendid
Mar 21, 2012
7,123
13
21,715
726
If you are not going to SLI/CF, 650W is a little overkill but not terribly so (520-550 is fine). If you think you *might* ever SLI/CF, I'd go at least 750W.
Edit: and I would agree that putting the Evo on when you initially build it is easiest. Since you have an unlocked CPU and mobo to support it, kind of a waste not to (given how insanely easy and safe it's become - 20%/4.2GHz overclock without any effort).
IntelEnthusiast
Splendid
Feb 10, 2011
2,789
261
+1 for headbomb
If you are overclocking you should get a 3rd party HSF to deal the increased temperatures.
Mar 22, 2013
41
well, if it needs 500w, it only leaves 150w free, also if I overclock that will take some more power, so isn't that a lot for the psu? Aren't you not supposed to run you psu at near its max capacity, or am I wrong?
geofelt
39,465
20
137,665
7,960
Overclocking a cpu does not significantly increase the power required. It is the graphics configuration that is most important.
A bit of overprovisioning for a psu is fine. A psu operates most efficiently and quietly in the middle third of it's range. It will consume only the power demanded of it, regardless of it's maximum capability.
Mar 22, 2013
41
ok, thanks i will go with the 650w and save myself some money
Mar 22, 2013
41
ok, thanks, im just kinda freaking out, because i've never even installed ram in a computer, much less completely built one. :??:
But, I think with these forums, and a little help from youtube videos, i should be able to pull it off :D
J_E_D_70
Splendid
Mar 21, 2012
7,123
13
21,715
726
Should toss in a $5 anti-static wrist strap to the order. Better safe than sorry. If you need the $5 for a latte, at least touch the metal frame inside the case periodically while working and don't drag your socked feet around on the carpet...
geofelt
39,465
20
137,665
7,960
You are good. The graphics card goes into the pci/e x16 slot. It will get 75w from the motherboard without any other connections.
The psu has a pair of aux p6/8 pin power connectors. The 6 pin part of each goes into the graphics card. Leave the +2 pins dangling; they are there in case your graphics card needed a 8 pin connector. Each one supplies up to 75w of added power for the graphics card.
Similar threads
