Question Do i need an aio cpu cooler or an air cooler
May 2, 2019
37
Hi guys,
my specs are
Motherboard - Asus Tuf h370 pro gaming
Cpu - Intel i7 8700
RAM - Corsair (2x8) 16gb 2666mhz
GPU - Gigabyte g1 1070
I would be playing games such as league of legends, rainbow six siege,
fortnite, GTA V, Apex legends and PUBG
Please help me decide whether I will be needing an Aio or just air cooler and recommendations of coolers if possible.
Thank you
The I7-8700 will come with a perfectly adequate stock cooler.
----------------how to mount the stock Intel cooler--------------
The stock Intel cooler can be tricky to install.
A poor installation will result in higher cpu temperatures.
If properly mounted, you should expect temperatures at idle to be 10-15c. over ambient.
To mount the Intel stock cooler properly, place the motherboard on top of the foam or cardboard backing that was packed with the motherboard.
The stock cooler will come with paste pre applied, it looks like three grey strips.
The 4 push pins should come in the proper position for installation, that is with the pins rotated in the opposite direction of the arrow,(clockwise)
and pulled up as far as they can go.
Take the time to play with the pushpin mechanism until you know how they work.
Orient the 4 pins so that they are exactly over the motherboard holes.
If one is out of place, you will damage the pins which are delicate.
Push down on a DIAGONAL pair of pins at the same time. Then the other pair.
When you push down on the top black pins, it expands the white plastic pins to fix the cooler in place.
If you do them one at a time, you will not get the cooler on straight.
Lastly, look at the back of the motherboard to verify that all 4 pins are equally through the motherboard, and that the cooler is on firmly.
This last step must be done, which is why the motherboard should be out of the case to do the job. Or you need a case with a opening that lets you see the pins.
It is possible to mount the cooler with the motherboard mounted in the case, but you can then never be certain that the push pins are inserted properly
unless you can verify that the pins are through the motherboard and locked.
If you should need to remove the cooler, turn the pins counter clockwise to unlock them.
You will need to clean off the old paste and reapply new if you ever take the cooler off.
Clean off old paste with alcohol and a lint free paper like a coffee filter.
Apply new paste sparingly. A small rice sized drop in the center will spread our under heat and pressure.
Too much paste is bad, it will act as an insulator.
It is hard to use too little.
The main reason one would want an aftermarket cooler would be to get a larger fan that will be quieter under load.
What is your case?
Without that spec, a cooler recommendation is not possible since most air coolers require 160mm available height.
From personal experience, I have used the scythe kotetsu at 160mm.
It is easy to mount, effective, and very quiet.
https://www.newegg.com/Product/Product.aspx?Item=13C-0004-00005
Here is a review:
http://www.silentpcreview.com/article1391-page1.html
May 2, 2019
37
What is your case?
Here is a review:
Hi my pc case is the phanteks p400s
What do you think about cryorig H7?
