Do I need an extra fan? And lighting.
askerforpc
23
This is the rig I want to build: cpu:intel i5 4670k $230
mobo:asus maximus vi impact $213
ram:gskill ripjaws 16gb 2x8gb $134 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231615
ssd:kingston hyperx 120gb $130
hdd:western digital caviar black 1tb $85
gpu:msi gtx780 lightning $770
case:bitfenix prodigy white $60
cooler:nzxt respire t20 $24
psu: XFX P1-750X-XXB9 750W $110
optical drive:asus BW-12b1st $75
os:windows 8 64bit $90
I just want to know if i can add extra coolers for less heat .( A fan that is not noisy?)
Also I would like to know if i could get some lights in my bitfenix prodigy case.
I'm guessing this is a gaming rig? I personally will not buy ram with spreaders - they perform no useful function and they tend to interfere with aftermarket air coolers. Also, 8gb will be more than enough for gaming.
You should probably add one more 120mm fan (use as intake) - get a high volume, low rpm type for least noise. There are lots to choose from, and the major brands are all good.
You can add lights if thats what floats your boat - led strips, cold cathode, etc are all available.
Thanks a lot could you tell me a specific fan. One that you will recommend .
