Do I need cable for NZXT Phantom case USB/eSata/audio?
jdx3ds
131
So I'm going to get the NZXT Phantom and Asus P8Z68 gen3 motherboard... the phantom has esata, USB3/2 ports and audio ports built in.. but what do I connect them to the motherboard with?
No, its coming with the case.
Front panel connections are the standard power/reset switch, power/HD LEDs, one USB, eSATA and front audio connections (HD and AC'97).
On the left is the eSATA...
http://www.overclockersonline.net/reviews/50003281/
Thanks! I did check manual for phantom but it is not very good.
Does the esata go into a sata port? I can't imagine needing an esata anything at this point though.
What is meant by HD and AC97?
