G Guest Guest Jan 4, 2017 #1 The title says it all. Do I need any of those? Here's my build: https://uk.pcpartpicker.com/list/6dKgr7 Thanks in advance!
Solution Dark Lord of Tech Jan 4, 2017 I would get at least one front intake fan. Fan Support: FRONT, 2 X 120mm REAR, 1 X 120mm @ 1200rpm (included) TOP, 2 X 120/140mm (1x 140mm included) BOTTOM, 1 x 120mm You don't need thermal compound it should come pre-applied. https://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?s=pc&ie=UTF8&qid=1483562440&sr=1-1&keywords=fan+hub I use this Sata hub for boards that don't have enough connections,
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Jan 4, 2017 Solution #2 I would get at least one front intake fan. Fan Support: FRONT, 2 X 120mm REAR, 1 X 120mm @ 1200rpm (included) TOP, 2 X 120/140mm (1x 140mm included) BOTTOM, 1 x 120mm You don't need thermal compound it should come pre-applied. https://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?s=pc&ie=UTF8&qid=1483562440&sr=1-1&keywords=fan+hub I use this Sata hub for boards that don't have enough connections, Upvote 0 Downvote Solution
G Guest Guest Jan 4, 2017 #3 I would get at least one front intake fan. Fan Support: FRONT, 2 X 120mm REAR, 1 X 120mm @ 1200rpm (included) TOP, 2 X 120/140mm (1x 140mm included) BOTTOM, 1 x 120mm You don't need thermal compound it should come pre-applied. https://www.amazon.com/SilverStone-System-Cables-Black-CPF04/dp/B00VNW556I/ref=sr_1_1?s=pc&ie=UTF8&qid=1483562440&sr=1-1&keywords=fan+hub I use this Sata hub for boards that don't have enough connections, So if I understand it correctly, I should get one fan in the front. That's all I need. I want to keep the price as low as possible. I don't need the SATA hub if I'm buying only 1 fan, right? Upvote 0 Downvote
