Build Advice Do I need different hubs for fans and RGB components?
Hasenn
9
I am going to buy a new PC build soon enough (full build: https://uk.pcpartpicker.com/user/Hakohn2511/saved/#view=QfTJbv)
It has 4 Be Quiet! fans, which are not RGB, but it also has some RGB components which are all supported by Asus Aura Sync (the Phanteks case, one Phanteks Halos Lux, and two Phanteks RGB LED strips.
In order for this all to work (and the RGB to be synced), do I need separate hubs, or are there all-in-one hubs? And, for the Be Quiet! fans, would a DeepCool fan hub work, or is it intended for and only for DeepCool fans?
