Do I need Dust Filters or Is mesh enough??
ShadowProject
121
I have been tossing up a few cases and I tend to love a case and then find out it has no dust filters for its intake fans. Is this a bit issue?? or does it just make cleaning a little bit easier??
Without dust filters it can be an issue if you don't clean your PC regularly because the dust will enter easily in your case and it may cause cooling problems.
With them you'll only need to wash/vacuum the dust filter and put it back in the case. It does make cleaning easier.
Any of these computer cases, comes with dust filters on every intake fan:
NZXT Phantom 630:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146101
CM Storm Trooper:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245
NZXT Switch 810:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146088
Corsair 600T:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139007
I don't know what style do you like so here's something less flashy:
Corsair Obsidian 650D:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
Antec P280:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129179
Fractal Design R4:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352022
Well you can buy individual filters for your fans, but to install them you'll have to screw them into the fan (Unless you use the magnetized design).
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999234
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999226
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999257
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999249
