Or can I just buy the unshielded cat6 RJ45 connectors?
Network Layout:
Motorola 2210-2 DSL modem -> Cat5e -> US Robotics Smart Gigabit Switch 8 port ->
garage (separate building from living quarters)
~50 meters.
Cat6 shielded outdoor runs here ->
Asus GX-D1051R1 5 port power-saving Gigabit Switch -> devices with Cat5e.
The problem was the Cat5e previously used got water in it, since it was not outdoor rated I assume (cracks from Sunlight formed somewhere me thinks).
Also, is it okay to put one more switch inside to shorten the run? I just read for the first time that this can actually degrade the signal. I was thinking of adding some more juice to it with a switch but this may not be correct.
Also, if I need to use couplers with this stuff later (inside) will I need shielded Cat6 couplers?
The cat5e in the network is all unshielded indoor rated patch as far as I can remember/tell.
Network Layout:
~50 meters.
