Do I need the 12v ATX cable plugged into my Z97 Pro Gamer?
handsomepigeon
Commendable
Jul 14, 2016
52
I just switched PC cases and because of the position of the PSU, the 12v cable can't reach the socket.
I also can't get it to boot. The LED on the power on button will light up, GPU light, fan will all turn on for at most, a second before stopping.
This could be anything but I have a suspicion that its to do with not having this cable in. In the manual it says that the computer won't turn on if its not connected but I want to double check before I go and buy a new PSU with a longer cable
If your case has gaps on the side the motherboard is attached to, thread the cpu cable out and then back in at top where the plug is instead of going over stuff to reach it.
