Do I need to change Graphics Card? Problem after installing Crimson
XenoCideXZ
15
After I install Crimson, my display starts flickering when I used Autocad & Photoshop. After 3 days black pixel (size: 8x8 pixel) appear
If I run is safe mode or uninstall crimson and drivers. there's no black pixel.
Do I need to buy new graphics or this is just a driver issue. THANKS
You might check gtx 950, it is very close in perfomance to gtx 960. Also might wait for pascal, but buget cards probably will appear later. Your cards gpu solder points might be damaged, also video cards ram might be faulty.
For now it sounds like a driver issue. How do you uninstall new drivers? Do you uninstall your older drivers properly? If you didn't, you should try Display Driver Uninstaller here:
http://www.wagnardmobile.com/
After that procedure, then try installing the new driver.
I used the AMD Clean Uninstall Utility. It will uninstall the crimson and drivers. I install the old Catalyst Control Center. after I install it will will the latest driver for my HD 7870, same problem.
CPU: AMD FX-6300 3.5GHz 6-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600
Storage: Samsung 830 Series 128GB 2.5" SSD
Storage: 500G WD
Video Card: HIS Radeon HD 7870 2GB
Power Supply: CoolMax 600W 80+ Certified ATX
Seems like a driver problem tho. No offense, but how many generations of catastrophic drivers will it take to make AMD Users switch to nVidia? I always wondered, why you would buy AMD instead. Any insights?
There is no base line in your argument. AMD drivers are not bad at all. Any driver can malfunction, look at Nvidia's last driver release. Full of bugs and crashes.
I use both AMD and Nvidia and to be fair, Nvidia have had driver issues as well.
Ok maybe mainboard problems, or to be more precise pcie slot? Have you tried different pcie slot? If that doesn't help, it might be some other fault with mainboard or your PSU, so at this point I would recommend to try different psu and then mainboard.
but if i uninstall driver the display is clear of black pixel.
I give up, i think crimson damage the graphic card. I can't fixed it no matter what. I plan to buy new card next week ang i'll pass radeon for now coz of crimson. I need suggestion. i'm low on budget, is gtx 960 is a good option
ok tnx, i'll try to.compare 950vs960.
