Do I need to connect my monitor through a graphics card?
thdfrance
13
I'm working on my first build, and I'm using an asus m5a97 LE R2.0 as my motherboard and eventually I'm buying an Asus GeForce GTX 660 as my graphics card. I was looking at my motherboard, and I didn't see an outlet to plug my monitor into. I was wondering if I needed to run my monitor through my graphics card, and if so how do I set up my build so that the cord runs to the outside of my case.
yep you will need to connect direct from your graphics then as the motherboard has no onboard graphics. Although it does have onboard sound, so you can use the sound either from your graphics or your motherboard!
