Do i need to get a fan header splitter?
Snip3o
110
Hello i'm about to buy my build but i want to make sure everything is good to go. Here are the parts i'm buying:
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($347.00 @ Centre Com)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($55.00 @ PCCaseGear)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($219.00 @ IJK)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory ($258.00 @ Shopping Express)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($109.00 @ Shopping Express)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($55.00 @ Centre Com)
Video Card: Gigabyte - GeForce GTX 1070 8GB G1 Gaming Video Card ($705.00 @ Centre Com)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case ($99.00 @ PCCaseGear)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($105.00 @ Shopping Express)
Case Fan: be quiet! - Pure Wings 2 140 61.2 CFM 140mm Fan ($16.00 @ PCCaseGear)
Monitor: ViewSonic - XG2401 23.6" 1920x1080 144Hz Monitor ($299.00 @ Mwave Australia)
Keyboard: Corsair - STRAFE Wired Gaming Keyboard ($128.00 @ Shopping Express)
Total: $2411.00
Generated by PCPartPicker 2018-07-02 00:47 AEST+1000
The main question i need answered is whether or not i need a fan header splitter to run all the fans i'm getting (CPU fan + 4 case fans).
Yes it does. That fan header has more power in case you connect an additional water pump.
You could have a CPU water pump and a GPU water pump on that motherboard.
But if I were you I would connect the 2 case fans to a splitter and the 2 be quiet! fans to another splitter for better cable management.
You have exactly 5 fan headers on that motherboard, but I wouldn't connect system fans to the CPU and Water Pump Fan Connectors
Get a PWM Y-Splitter and connect two be quiet! fans to it. Those fans have 3-pin headers but if you decide to go with 4-pin fans you won't have to look around for another splitter.
2 fans also come with the case, what will i do about that?
Simple, connect them to the motherboard or get another fan splitter.
You have 5 fans header
1- CPU header (CRYORIG - H7)
1- Water cooler (in case you get one later)
3- Fan headers
You will connect the be quiet! fans with a splitter to a fan header, so you have two fans headers empty.
You could connected the case fans to the 2 empty fan headers or get a splitter and you will have one available.
The case fans might come with a Molex connector and if you use that connector they will run at full speed and it could get loud.
OK so does the "Chassis Optional/Water Pump Fan Connector" count as one? Because other than that i only see two Chassis fan connectors in the specs.
Ok awesome, is this kit fine?
https://www.pccasegear.com/products/28236/noctua-4pin-11cm-pwm-fan-power-splitter-cable-2-pack/
Sorry for bothering you again but i just want to make sure. So i can plug a 3 pin fan into a 4 pin PWM header (and the splitter) without any problems?
OK awesome, thanks so much for the help!
