do i need to hook up my monitor to my video card or my motherboard
ZombieBunny
20
I purchased a monitor and i was wondering if i should hook up the monitor to the graphics card or the mobo and why should i hook up the monitor to one of the other also if i use a vga to dvi adapter will it affect performance at all?
why is it better? and if i use a vga to dvi adapter will there be a performance hit?
Video card has better performance than internal graphics and the reason dvi is better to use than vga is... check this youtube video:
http://www.youtube.com/watch?v=xMVDejZH4kw
Hope it helps 😀
