RacAtat007 Distinguished Aug 8, 2012 219 6 18,695 Jul 12, 2014 #1 This is my first time mounting an ISO and I got it to work fine but ,y question is, Will I need to go through the process everytime I run the program I mounted or is it a 1 time thing?
Solution A A Alabalcho Jul 21, 2014 Think about "ISO mounting" as "Inserting the CD into the drive". If you need that CD for your program to run, you will have to mount the ISO.
USAFRet Titan Moderator Mar 16, 2013 178,536 21,398 184,590 Jul 12, 2014 #2 An ISO of what? Once mounted, it will be there until you reboot. Upvote 0 Downvote
RacAtat007 Distinguished Aug 8, 2012 219 6 18,695 Jul 21, 2014 #3 USAFRet : An ISO of what? Once mounted, it will be there until you reboot. OK thank you Upvote 0 Downvote
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 Jul 21, 2014 Solution #4 Think about "ISO mounting" as "Inserting the CD into the drive". If you need that CD for your program to run, you will have to mount the ISO. Upvote 0 Downvote Solution
