_Whitedragon_ :
azaran :
Naw you can use the supplied paste. Its not the best, but it'll work, much like the cooler really. If you want to apply your own tho, just make sure to clean the heatsink of any paste on it beforehand.
Am new to pc building thing, can you tell me how I can safely clean the thermal paste on the cooler and also on my CPU if I would need to in the future? and also do I have to keep cleaning the paste and applying every month or so to keep my CPU safe or I can just do it one time and forget about it?
I would recommend you to re-apply the thermal paste on your own as there is a chance that whoever built your PC (assuming the store which you bought it from built it as well) is inexperienced and messed up by spreading the thermal paste or whatever, because that's what most employees do in stores.
Why am I saying they messed up by spreading the thermal paste? Well, when you apply thermal paste, you shouldn't spread it because when you put the heatsink on it creates air bubbles and thus your CPU can get quite hot. On the other hand, if you just add a little in the center (about the size of a little pea) of the CPU and put the heatsink on, it will evenly spread, and as it gets hotter, it will spread even more on its own.
Now, when removing thermal paste, make sure you get microfiber cloth and isopropyl alcohol. Safest and fastest way to remove thermal paste.
![Smile :) :)](/data/assets/smilies/smile.gif)
Always be careful not to get thermal paste on your skin OR any PC components when applying / removing thermal paste as it is corrosive and conductive.
As of your question whether you should reapply thermal paste once a month or not, well, it's always good to do it once every month or two months because it dries over time, not to mention the heatsink and fans get dust all over...
If it seems like a struggle, always remember that other people need to maintain their hydro coolers every week.
I highly recommend you use Arctic Silver 5 thermal paste as it's high quality, but your stock thermal paste should do just fine if you apply it correctly.
I also highly recommend you to check this video here:
https://www.youtube.com/watch?v=-hNgFNH7zhQ
This is literally where I learned how to apply thermal paste correctly when I was a beginner. Helps out a lot by making you understand why you are doing all of these steps
Good luck, and I hope I helped!
