I bought overclocked water cooled PC 4 years ago - and never replaced "water" (it proper cooling fluid). So after 4 years.. do I need flush/replace?
My concern is that it does not have a nice draining solution - so I would have to take it apart.. and if I do - I dont know if that means tubes/seals need to be replaced, or if they should all be OK to reuse. Of course - once I break the seals.. I dont want to have to rush around if it does not reseal well etc.
Conversely - I dont want to just leave it - if it getting to point where it might spring a leak.
So what is the best option?
I think pump is a XSPC D5
Thanks in advance for sage wisdom/advice.
Cheers
Cheers
