[SOLVED] Do I need to screw my motherboard into every standoff?
ProPlayerGR
595
42
19,040
Hello guys. I recently built my first pc and I was wondering if I should screw my motherboard into every standoff. My motherboard is the b450 tomahawk. My case is the corsair obsidian 750d airflow edition. I have screwed every screw apart from the middle one because there's one screw from my case that takes its place. Should I do something about it or no? Thanks in advance.
Reactions: Arkinstien
Can't see very well, when photo is taken through glass.
Is the spacer something like this?
Anyway - it looks like providing some support to motherboard. Probably is fine.
Can you show any photos illustrating your issue?
Generally - yes.
Every standoff place in your motherboard needs to have corresponding standoff and screw.
View: https://imgur.com/LGxMeQz
View: https://imgur.com/YWMUTBL
It's a bit dark I know. I don't know if you can see it but there's a black screw from my case sticking through that hole and as a result I can't screw a standoff there. Should I leave it as it is?
