Do I still need to reinstall my OS when I'm changing my motherboard?
ZipX
Commendable
Jan 2, 2017
Hello Guys,
I'm a Win7 user and planning to change my mini-ITX motherboard into an ATX motherboard.
My question is, do I still need to reinstall my OS? I'm buying the same brand which is Gigabyte.
Here is the link of my current Motherboard: https://www.gigabyte.com/Motherboard/GA-F2A85X-UP4-rev-10#ov
And here are the links of the motherboard that I'm planning to buy: https://www.gigabyte.com/Motherboard/GA-F2A88XM-D3HP-rev-10#ov
https://www.gigabyte.com/Motherboard/GA-F2A68HM-DS2-rev-10#ov
Any suggestion/answers will be appreciated.
I think not.
If your new motherboard has the same or similar chipset, your current windows C drive will likely boot on the new motherboard.
Try it.
If you can boot, you can install the drivers that come with your new motherboard.
This avoids the hassle of reinstalling your apps and doing a new clean install.
