Question Do I want a plexi/acrylic top for my block or pump?
Mar 17, 2019
51
For i9-9900.
I'm leaning towards EK, but any universal waterblock as well. They have plexi/acrylic and all-copper tops. Also options for stand-alone pump tops.
I think I want a clear top, to see any algae or corrosion inside. But has anyone had any trouble with them cracking? Otherwise, would a copper top assist in cooling? I like the look of nickel-plating, but functionality comes first.
copper top doesn't add any cooling, its just looks
i have one with black screen on top ( block is transparent but have black screen on top ) due to which i can't see its inner from top ( came with s360 kit )
no cracking will occur unless you use hammer or alcohol on acrylic top or throw it out hard
Reactions: Craig C2
