R rey3567 Honorable Dec 21, 2013 20 0 10,510 Dec 21, 2013 #1 I have a Gigabyte GA-990FXA and im wondering if i need to buy one of those wireless networking adapter.
Solution bignastyid Dec 21, 2013 Some do most don't. The model you posted doesn't have built in wireless.
bignastyid Titan Moderator Jun 19, 2011 33,688 1,700 159,590 Dec 21, 2013 Solution #2 Some do most don't. The model you posted doesn't have built in wireless. Upvote 0 Downvote Solution
Beezy Dignified Nov 4, 2013 4,037 0 15,960 Dec 21, 2013 #3 yeah you need to buy a pci or pcie wifi adapter, the TP link ones work well and are priced well. This is OK for surfing the web and stuff. http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Delectronics&field-keywords=tp%20link%20pci&sprefix=tp+link+wi%2Caps%2C224&rh=i%3Aelectronics%2Ck%3Atp%20link%20pci This one is a little more expensive but id twice the speed http://www.amazon.com/TP-LINK-TL-WN851ND-Wireless-Adapter-Low-profile/dp/B005NHIQ06/ref=sr_1_6?s=electronics&ie=UTF8&qid=1387673030&sr=1-6&keywords=tp+link+pci Upvote 0 Downvote
