1 1967275544 Prominent Jul 6, 2017 44 0 530 Jul 8, 2017 #1 This is my first time building a PC: does anyone know if the monitor requires power cables? Also, how long are typical HDMI cables?
Solution ThatVietGuy Jul 8, 2017 1967275544 : ThatVietGuy : Do you mean a power cable from the PSU of your computer? No, monitors have their own power supply and the get supplied by your wall socket. HDMI cables are usually 3-6ft long. So, the monitor comes with a power cable? Also thanks for answering the HDMI cable question. Correct. Monitors plug into the wall, as I said.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Jul 8, 2017 #2 Do you mean a power cable from the PSU of your computer? No, monitors have their own power supply and the get supplied by your wall socket. HDMI cables are usually 3-6ft long. Upvote 0 Downvote
1 1967275544 Prominent Jul 6, 2017 44 0 530 Jul 8, 2017 #3 ThatVietGuy : Do you mean a power cable from the PSU of your computer? No, monitors have their own power supply and the get supplied by your wall socket. HDMI cables are usually 3-6ft long. So, the monitor comes with a power cable? Also thanks for answering the HDMI cable question. Upvote 0 Downvote
J_E_D_70 Splendid Mar 21, 2012 7,291 59 30,290 Jul 8, 2017 #4 Yes, monitors require the power cables that come with them. HDMI can be many sizes from maybe 3' to 6 or 10. Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 32,864 4,856 126,640 Jul 8, 2017 #5 Of course - every monitor requires power. And there is no "typical" length for HDMI cables. You take whatever length you need - 1m, 1.5m, 2m, 3m, 5m, 7m .. up to 15m. Longer cables will require signal amplification. Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Jul 8, 2017 Solution #6 1967275544 : ThatVietGuy : Do you mean a power cable from the PSU of your computer? No, monitors have their own power supply and the get supplied by your wall socket. HDMI cables are usually 3-6ft long. So, the monitor comes with a power cable? Also thanks for answering the HDMI cable question. Correct. Monitors plug into the wall, as I said. Upvote 0 Downvote Solution
K kevinzou442 Commendable May 27, 2018 16 0 1,510 Jun 4, 2018 #7 if i unplug the power cable from the wall socket by accident will my monitor shutoff or is the power cable just for the battery of the monitor? Upvote -1 Downvote
SkyNetRising Titan Jan 4, 2016 32,864 4,856 126,640 Jun 4, 2018 #8 kevinzou442 : if i unplug the power cable from the wall socket by accident will my monitor shutoff or is the power cable just for the battery of the monitor? Monitors don't have batteries. It will turn off. Upvote 0 Downvote
