Do my case connectors fit my motherboards
Zic
Respectable
Dec 21, 2016
252
hi I was wondering if my case connectors fit my motherboard connectors here are some screen shots of all the motherboard and case connectors and if they all fit do I need anymore or are those just the Chassis functions and the ones that my chassis doesn't have I don't need.
Motherboard Connectors
http://imageshack.com/a/img922/7296/Usskmk.png
http://imageshack.com/a/img923/644/qBcXlx.png
http://imageshack.com/a/img924/9660/YcM3yP.png
Case Connectors
http://imageshack.com/a/img923/6046/p3Qo1B.jpg
Case
http://www.corsair.com/en-us/carbide-series-air-540-high-airflow-atx-cube-case?utm_medium=Affiliate&utm_source=PCPartPicker%2C+LLC-2993279&utm_term=3938566&utm_content=&utm_campaign=12661062&Link_name=Corsair+US+Product+Catalog
Motherboard
https://www.asus.com/us/Motherboards/SABERTOOTH-Z170-S/
Thanks
Yes, the fit just fine. Your case doesn't have a USB2.0 connector (as you have USB on the case), so disregard that one.
As an FYI, you don't have to use the ASUS Q-Connector if it's difficult to visualize.... but it helps.
