Do my PC components work great to each other?
chinh.ln1902
7
Hi, I am building my PC but I'm not entirely sure if all of these components are compatible with each other. Will they bottleneck to each other? I would really appreciate it if you could take a look at my selected components and tell me if they are all compatible with each other or not. Thank you in advance!
CPU: Intel Core i7-5820k 3.3GHz
Motherboard: MSI X99S SLI Plus MS-7885
GPU: ASUS GeForce GTX 1080 8GB ROG STRIX Graphics Card (STRIX-GTX1080-A8G-GAMING)
Ram: Corsair Vengeance 16GB (2x8GB) DDR4 DRAM 2400MHz
Power Supply: CS Series™ Modular CS850M — 850 Watt 80 PLUS® Gold Certified PSU
yes, it will work. However, you need to add a cooler like Noctua D15 or H100i. PSU is not good. Assume your major usage is gaming or editing. Ryzen is best bang for the buck, I will get something like this:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($193.67 @ OutletPC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard ($69.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($154.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($94.99 @ B&H)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.69 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card ($532.00 @ Amazon)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($45.98 @ Newegg)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $1177.20
Generated by PCPartPicker 2017-11-02 01:26 EDT-0400
So can you suggest some PSU for me? This is the PSU my brother gave to me from his old PC, I though it is good enough because it provides 850W which is enough for whole PC. So will this PC creates bottleneck when running?
Awesome. However do you have any suggest for the PSU?
If you don't want to spend on PSU right now, use that CSM but plan to get a new one soon. I personally won't trust that old and no good PSU with my expensive new parts. Get Seasonic recommended.
For mine, because the PC i'm planning to build has different components from the one of vapour.
Gotcha! Thank you.
I couldn't find any button to solve this thread, can you help me?
Below each answer, you will find a "Pick as solution" button clicking that button under the answer you prefer will select the best answer.
I couldn't find any button as you said. Check this photo, there is no "Pick as solution" button.
https://www.dropbox.com/s/ju94hq9goiugvun/Capture.JPG?dl=0
