Do Noctua NF-A14 Fans connect into NZXT Phantom Fan Hub?
dbakuji
22
Or do i need to use NZXT fans? I am trying to decide what fans i should get that work with my fan speed control on the phantom 530 case.
And if Noctuas do work, which kind do you suggest i use? The FLX, ULN or PWM?
No really Nuclear.
The P530 offers a fan hub that support any 3 pin fan connector. If you want to install 4 pin PWM fans then, its not going to work.
Just make sure that the fans that you want to install are all 3 pin and you can use the stock fan hub on the case without any problems.
