Do PCs usually come with the cable to connect to a monitor?
The PS4 has a HDMI output. If your PC has an HDMI output (most do) you can use that cable.
Thanks for the reply.
Do you know if the cable that comes with a PS4 will work for connecting a monitor and PC, or do I have to purchase one
mine did ...it came with a vga....saddly this connectors are so old that they could misbehave with your monitor like it did on mine for some reason....switched to hdmi and problem was solved ^_^
Did you have to connect the HDMI to the video card?
no i just switched the vga cable for the 1.0 HDMI ....well basically the HDMI connector is in the video card so yes i did .
Im planing to get the 2.0 version.....much better than 1.0
