Do the Gigabyte GA-H81M-S1 able to support the 2 fans (front and rear fans) on Antec X1-T cabinet ?
Ragesh Antony
8
I am building a PC. I selected Antec X1-T cabinet . I have 1 front fan and 1 rear fan. I selected Gigabyte GA-H81M-S1 Motherboard. But this MB have one 1 system fan header. What does it means. ?
Can if connect that 2 fans on the cabinet on the motherboard. ? If not , what can i do ?
Can I use this product "CNCT CPU FAN POWER CABLE 3 PIN TO 4 PIN - to connect 3 pin Fans to Standard Computer Power Supply from Cooler Master - Antec - Corsair - Thermaltek - NZXT" (link : http://www.amazon.in/CNCT-CPU-FAN-POWER-CABLE/dp/B00SBQC2M4/ref=pd_cp_23_1?ie=UTF8&refRID=038YHRW0V2YDA227Y6YH#productDetails)
Do the PSU Corsair VS450 450 Watt PSU support above CPU FAN POWER CABLE 3 PIN TO 4 PIN ?
Pls tell me all possible methods to resolve this fan issue ?
1 x 120 mm front red LED intake fan
1 x 120 mm rear exhaust fan (optional)
1 x 120 mm side intake fan (optional)
1 x 120 mm front intake fan (optional)
Download the motherboard manual and check the motherboard diagram for available chassis fan headers on the motherboard.
You may get an adapter with the fans you choose to buy.
