Question Do the keys from Logitech G213 suit G Pro with linear switches?
sirdariush
35
My S key broke yesterday. The G Pro linear switch is my favorite and I don't want to change it. Is it possible if I buy a G213 keyboard to switch the S key from that to the G Pro? Are they even the same?
DSzymborski
Unless I'm mistaken, the G213 keyboard doesn't have mechanical switches but membrane switches that it dubs "mech-dome" based on the claimed performance. You will need a Romer G switch and there will be soldering involved.
sirdariush
35
Thanks for the reply! Although, I am referring to the plastic key, not the switch. Are the plastic keys on the G213 the same as on the G Pro?
