do these have HDR light rendering/capabilities?
mthomas99
148
Hi, I have a question about these cards , do any of them have HDR rendering?
6600GT
http://www.newegg.com/Product/Product.asp?Item=N82E16814150098
6800GS
http://www.newegg.com/Product/Product.asp?Item=N82E16814150118
6800GT
http://www.newegg.com/Product/Product.asp?Item=N82E16814121192
http://www.newegg.com/Product/Product.asp?Item=N82E16814135171
X850XT
http://www.newegg.com/Product/Product.asp?Item=N82E16814102505
Everyone of these cards is $110-$225 -- which one of (*These) cards would you recommend for the best bang-for-the-buck?
Also, which ones support High Dynamic Range Lighting (HDR), if any?
thanks for all your input
-mike
The nVidia 6 & 7 Series (6600GT to 7800GTX) have Shader Model 3.0 and HDR, only the ATI Radeon x1000 Series (x1300 to x1900) have Shader Model 3.0 and HDR, x800 Series and below (x850 to x300) have no HDR or Shader Model 3.0. If you're choosing between 1 of those cards, get the x850XT, performs better than the other 3, I know this because I have all 4 cards, the x850XT is the best.
