Do these parts fit in the Fractal Node 304?
CPU cooler: check
Graphics card: check*
PSU: check*
*see the following from Fractal:
"Graphics cards, up to 310mm in length, when 2 HDD brackets (1 HDD hanging bracket total)
are removed (Graphics cards longer than 170 mm will conflict with PSUs longer than 160mm)"
That graphics card is 284.9mm, that PSU is 160.02mm
Everything should fit fine, but you will need to remove one of the hanging HDD brackets. PSU and GPU should just clear.
I would highly recommend lower profile RAM so you don't have an issue with the CPU cooler (the Ripjaws you listed might fit, but you might need to tweek the position of the fans on the heatsink and whanot). Check out this stuff, it is excellent: http://www.newegg.com/Product/Product.aspx?Item=N82E16820104231
This is kind of the low profile version of the Ripjaws: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231542
