Do these specs work well with each other?
Joekiller385
8
CPU: AMD Ryzen 7 1800X
CPU Cooler: Cooler Master - Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: Zotac - GeForce GTX 1060 6GB 6GB Mini Video Card
Case: Rosewill - NAUTILUS ATX Mid Tower Case
Power Supply: CX750M
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g
Nice build just get a 650w psu instead of a 750w because you are only using a single gpu and 750w is a bit of an overkill for a 1060 unless you want to sli later on..... other than that perfect
As something possibly worth considering, if this system is for gaming, a Ryzen 2600X should be slightly faster than an 1800X in most of today's games, despite having only 6 cores, due to some minor improvements to the 2nd-generation architecture and improved boost clocks. It's certainly possible that the 1800X's extra cores may help at some point in the future, but as of now, games don't tend to utilize that many cores, and most developers still try to make sure their games run well enough on quad-core processors. The 2600X also comes with the Wraith Spire, which is a relatively capable stock cooler that should actually perform fairly similar to a smaller 92mm tower cooler like the Hyper T2.
