I'm thinking of installing a TV Tuner Card. Looking at pictures on Newegg, I see in the back of the $60+ models a coaxial cable. I assume you're supposed to connect your wall cable to that... (and it may or may not work depending on my cable provider's encryption, based off what I've read).
But I was wondering how it works with over-the-air channels? Can you just plug in a rabbit ear antenna? If so, can those channels be recorded?
Have any tips or suggestions on buying/using a tuner card?
