P Patrick_143 Prominent Feb 28, 2017 14 0 510 Mar 11, 2017 #1 Do you need to install a cpu for the hdmi dvid vga ports to work. everything else is installed besides os & of course cpu. thanks
Solution PC-4LIFE Mar 11, 2017 If you don't have a CPU you cannot POST. The CPU is essentially the brain of your computer, without it nothing is possible, NOTHING.
USAFRet Titan Moderator Mar 16, 2013 179,732 22,226 184,590 Mar 11, 2017 #2 Patrick_143 : Do you need to install a cpu for the hdmi dvid vga ports to work. everything else is installed besides os & of course cpu. thanks Yes. Upvote 0 Downvote
PC-4LIFE Respectable Nov 14, 2016 1,017 0 2,660 Mar 11, 2017 Solution #3 If you don't have a CPU you cannot POST. The CPU is essentially the brain of your computer, without it nothing is possible, NOTHING. Upvote 0 Downvote Solution
bgunner Judicious Feb 13, 2009 5,153 27 32,540 Mar 11, 2017 #4 Yes, the CPU coordinates all other pieces so they will work together. No CPU, nothing will work properly. Upvote 0 Downvote
