My Asrock z490 taichi has 2 of them, so does the corsair 850 PSU. The manual says they are optional. What are they for then? Doesn't the mobo get the power it needs from the main 24 pin? It's a modular PSU so I'd rather not clutter it up if it's unnecessary.
Also when it comes to wiring the GPU is one cable OK? It's an RTX 2080 that needs an 8 and a 6 pin. Saw a youtube vid that says you should use 2 different cables to spread the load. So like 1 cable for the 6 and 1 for the 8? Is that also necessary or can I just use 1 cable since each cable goes from 8pin from the PSU and splits to an 8 and a 6? It seems unnecessary to spread the load.
What if I was running 3 GPU in 3 way crossfireX mode? Then it would have to be 1 cable per GPU. Again, I don't want to rout extra cables if I don't have to. lol I already suspect my cable management is going to look like a joke so I want to make it as easy on myself as possible.
Sorry for the newb questions, this is my first build.
https://download.asrock.com/Manual/Z490 Taichi.pdf
