does 1 8gb generate less heat than 2 4gb?
Here's an example (using http://extreme.outervision.com/PSUEngine):
DDR4 2x4GB produces 3 watts
DDR4 1x8GB produces 3 watts
DDR3 is a little less efficient but not significantly so.
Sounds like you need to work on your system to get good air flow through it. You should have air in take fans in the front and exhaust fans in the back creating a flow of air in the from and out the back. Be sure the vents a clear of dust and anything blocking the air flow in and out of your case. Heat is the enemy of your computer. It is better to run 2 x 4gb sticks then 1 x 8gb stick.
