Hi!
so recently i just bought my self a 144hz monitor which is Viewsonic XG2401, and then a saw a performance decrease in FPS
Before i use this XG2401 monitor i was using Sony Bravia 24" tv + samsung 19" monitor and i can play R6 siege with max setting in around 90+ FPS and CSGO with max setting around 260+ FPS
after i use this XG2401 + sony 24" tv i only achive 100 FPS on lowest setting
then i remove the sony 24" tv and it only increase the FPS to 120+ on the lowest setting for R6 Siege, and 250 FPS on the lowest setting on CSGO
So can anyone help me figure out what happen? is the monitor the source of the problem?
my spec:
Asrock x370 Gaming K4
R5 1600 @3.7Ghz (watercooled)
G.Skill Ripjaws V 2x8GB 2666Mhz
EVGA GTX 1070 FTW ACX 3.0
Adata SX8200 Pro 256GB
Samsung 860 EVO 500GB
Thanks!
Update:
so i found a little clue,
my monitor set to 144hz, and then i find out that there is a setting option for refresh rate in R6 Siege so i set it to 120Hz and the FPS increase up to 150FPS, but when i set it to 144hz the fps is decrease back to 120ish or lower
my spec:
Thanks!
Update:
