Question Does 4 pin ATX work on 8 pin?
undertaker24260
21
CPU- I3 9100F
Motherboard- MSI H310M PRO VDH PLUS
RAM- Corsair Vengeance LPX 8GB DDR4 2666MHZ
GPU- GT 1030
PSU- ISO-400PP
I recently just bought the ram cpu and motherboard and the motherboard had an 8 pin atx power cable but I only have a 4 pin cable. Will it work fine without burning the components. PS. I know my psu is very bad but will it still be fine?
That PSU is more of a firestarter. You should swap it out for a reliable unit. Thumb rule: You should pick a PSU that has the right connectors for your motherboard.
You want to risk everything in spite of knowing the PSU is bad? It's the same as trying to get into an accident without an airbag or a seatbelt.
^ No offence but during this pandemic, ever resource is precious. In this case, it's the money you spent.
I dont really have money for a new psu atm but I have a psu upgrade planned definitely. I just want to know if it'll work fine for atm
CPU- I3 9100F
GPU- GT 1030
PSU- ISO-400PP
Even with the psu being bad etc will a 4 pin work fine as I have ordered a connector for 4 pin to 8 pin but it will take alot of time to come due to The current situation around the world. If I use the 4 pin for now will it work fine??
