Perhaps my google-foo is poor, but there does not seem to be any aftermarket pre-made cable options for Intel/ASRock NUC's 5v PWM Fan connector (1.25mm pitch). Is this a "build your own cable" problem, or am I searching for the wrong keywords?
I got the Micro PH 2.0 4-pin (GPU fan plug) but that was too large, and it turns out I need the 1.25mm Pitch (PicoBlade) size.
Context: I am attempting to install a Noctua (5v) SF-A6x25 on aftermarket heatsink in a NUC, and want BIOS controlled PWM, so I need to step down the fans 4-pin PWM to a 1.25mm pitch socket on nuc board.
