Does a 4-pin AIO Pump need a 4-pin header?
Suncream_1
Commendable
Jan 22, 2017
19
I'm getting a masterliquid 240 and I need the pump to ideally plug into the 3 pin chassis header on my mobo.
Just wondering if it will work, or whether I should just get a molex adaptor to plug directly into the psu.
(extra: I plug my aio fans into the cpu header right?)
Ahh I get ya-in this case you can connect the rad fans to the CPU fan header and the pump to any of the other 2 fan headers but make sure you change the settings in BIOS for the pump header to operate at full capacity. Otherwise you can use a molex to 3 pin adaptor and hook it straight onto the psu.
I have an asrock ab350m pro4 which has only 1 cpu header, 1 pwm fan header, and 1 3-pin fan header. There is no CPU_OPT/pump header
just to be clear, am I able to connect the 4-pin pump to the 3-pin chassis fan header?
